Arena 6 : Quit : The Mediamanager is busy.
eloi.maduell
Post by eloi.maduell »
Hi !
I've been having some issues when opening a Composition file made in Arena v6 from a Japanese fellows. The locator of files seems that doesn't work properly, so I click on locate, I locate the file and usually on Arena 5 it was able to find the missing files on that same folder, but this doesn't seem to work on Arena v6 ?¿
So what I've done is to relocate all the files 1 by 1 (104) manually ... but then when I quit Arena 6 ... it thows this message :
The Mediamanager is busy. Do you really want to quit ?
If i press yes ... Arena v6 hangs ... ?!¿
Is this a know bug ? Any ideas ?
Maybe is because the path that I got from the Japanese guys had special characters (japanese) that makes everything to stop working properly ?
Why Arena v6 gets stuck in the MediaManager if I've already relocated all the files ?
I'm OSX by the way ...
I've to kill the process (Force Quit) and then I can reopen the file correctly ...
e*
Re: Arena 6 : Quit : The Mediamanager is busy.
Could you drop us a [email protected]? We could use your help testing a fix for this.
Moreno oro
Post by Moreno oro »
I'm Having the same issue (just sayin)
The quit message "Mediamanager is busy" will be fixed in the next release.
We're still working on the relocating not working when moving from windows to mac and vice versa part
