Autopilot and selected Clip
eloi.maduell
Post by eloi.maduell »
Hi Resolume's !
I'm wondering if there is any way that when you have AutoPilot to play "Next Clip", the Clip window gets updated showing the new Clip that is playing because of autopilot?
I would love to be able to have visible the clip properties of the clip that is playing because of Autopilot programation to play "Next Clip" ... Do I explain ? Is that possible somehow ?
Thanks again !
e*
Re: Autopilot and selected Clip
eloi.maduell wrote:I'm wondering if there is any way that when you have AutoPilot to play "Next Clip", the Clip window gets updated showing the new Clip that is playing because of autopilot?
This is currently not possible.
vj granda
Post by vj granda »
And will be possible some day??
vj granda wrote: Tue Jun 12, 2018 11:01 And will be possible some day??
We don't have this on our roadmap.
This would also not be possible with auto pilot set to random.
How would you like this to work with multiple layers set to auto pilot, which layer's next clip would be selected?
You could do this with a simple processing sketch via OSC, that would listen for the clip launch and would send a clip select back to Resolume.
