Crash Resolume 5.1.4
Mael
Post by Mael »
Hello,
I have problem with Advanced output with 5.1.4
My configuration
Windows 10 PRO
I7 - 7700HQ
GTX-1070
16GO RAM
When i run Advanced output The resolution of the screen is not the same as the real life ans when i selec my screen Resolume crash.
What is the problem ?
Best greetings
Re: Crash Resolume 5.1.4
Check your windows scaling options.
right click on your desktop and click display options. scaling should be the very top option, make it 100%, you're probably sitting at 125-175% if i was guessing.
Best to just turn windows scaling off completely (requires a log out then log back in)
