APC 40 MKII midi issue
mrclean808
Post by mrclean808 »
Hello, for some reason the APC 40 MKII does not some to work with Resolume 6. I've checked to see if it is working via MIDI preferences, and also that that all proper MIDI preferences were selected and everything shows that theres activity yet the controller doesnt actually trigger anything. It does work if I try manually mapping the controller. How do I activate the apc40 mkII preset? Im assuming its naturally selected when connected? Thanks in advance!
Re: APC 40 MKII midi issue
mrclean808 wrote:Im assuming its naturally selected when connected?
No it's not.
You can select it manually entering Shortcuts - Edit Midi.
Then in the shortcuts panel in the preset list there is the APC 40 mkII preset.
vjculture
Post by vjculture »
It seems that my turning on midi out disables the APC 40. It use to work fine and then stopped working.
As long as I don't turn on midi out, I can receive midi from the APC 40
Could you send us a screenshot of your midi settings?
Which Resolume version are you using, on which OS?
vjculture
Post by vjculture »
thanks for asking. I'm running 6.05 on a PC running windows 8.1pro
The touring rig is not online so I'll share photos from my phone.
