multiple audio channels
Supernova
Post by Supernova »
I just got a request from a client to basically have audio output 1&2 cover all the audio from layer 1, and audio output 3&4 to cover all audio from layer 2. I know in Resolume 5 only two audio channels were supported. Is this still the case in Resolume 6?
If so, what would be a good work around for this need? Would it be practical/possible to make layer 1 only output on the left audio output, and layer 2 only output on the right audio output?
Thanks in advance!
Re: multiple audio channels
Resolume 6 also outputs on 2 channels.
2x stereo outputs you need is not possible in Resolume currently.
You could do 2x mono as one stereo output by panning the layers to the left and right respectively.
