Resolume 6 Wave Warp
enjoykaos
Post by enjoykaos »
Hey guys,
R6 Wave Warp. When you put the speed level up the wave becomes less smooth. Ive recorded a few speed settings with sin and with tri selected. The bits at the end are examples of how im using the wave warp just for fun. I used it a lot on 5 and it definitely didn't do this.
Im also wondering if the pin is right. Haven't illustrated that in the video but it seems to only really pin three of the sides.
cheeeers in advance))
enjoykaos
Re: Resolume 6 Wave Warp
Post by enjoykaos »
b u m p
To me it looks like the behavior is the same as in R5 regarding the smoothness, and edge pinning.
enjoykaos
Post by enjoykaos »
hmm oki im pretty sure 5 didnt glitch like that.. but actually i mostly never pushed the speed so much. ill give it a test..
enjoykaos
Wave warp jaggies
Post by enjoykaos »
Hi guys, i posted about wave warp a while ago - thinking it had broken when it was remade for 6. I just checked back to 5 and as was suggested it is the same, so not broken in 6 as such more like always a bit broken. :) dont want to seem ungrateful - big Resolume fan.. but is it possible to make it so that when you increase the speed it stays smooth.. currently the default preset looks like a cross between the square and sine unless you put the speed to 0 or near to.. Would suggest making the default preset have speed = zero - it really looks kinda bad coming out like that.. Also.. the pinning isn't great - to make it go edge to edge you have to make the source oversize.
love n lumens n that ;)
Re: Wave warp jaggies
enjoykaos wrote: Fri Feb 22, 2019 09:34is it possible to make it so that when you increase the speed it stays smooth.. currently the default preset looks like a cross between the square and sine unless you put the speed to 0 or near to..
Which Resolume version are you using exactly now?
You know, you can create presets ;) https://resolume.com/support/en/effects#presets
Have you tried the wave warp before Transform?
enjoykaos
Post by enjoykaos »
Hiya Zoltan.. was actually looking at how to to tag you in that post thanks for the consolidation..
Using latest resolume 6 arena on windows 10 machines.
Yes very familiar with the results of placing effects on either side of the transform.
I can make presets, coff lol, no way, how is that possible?
Um yeh anyway seems a shame that the wave warp will remain knackered. i will continue to use it extensively.
Aand yeh.. shurely it would make sense to be able to make it wave without introducing the jaggies. Perhaps its difficult to achieve.
enjoykaos
Post by enjoykaos »
Ok so yeh just went back to check on this. Pinning does not work regardless of where the transform is.
And when you have the effect sped up the sine looks like a stepped sine. :roll:
Resolume 6 win10 etc etc.
Tempted to engage in sarcasm at this point but yeh, im sticking by my earlier assertion that wave warp is broken. Literally just trying to help improve the program.
Which 6.x.x version exactly?
We have a ticket for this, but I can't seem to be able to recreate any more on my machines.
The problem is that the behavior has been this way since Wave Warp was introduced in Resolume 3 and people are used to how it works. When we make even the tiniest changes to effects, people will notice and rightfully complain. The Stingy Sphere rewrite on Resolume 6 was a good example of where we ended up spending way too much dev time on this.
So even though you make a good point that it can be considered broken, it’s a big call for us to introduce any changes to it.
