AJA Kona 3 no Capture Device in source list
schneidi
Post by schneidi »
im trying to use Resolume VJ Software with my 2 "Aja Kona 3" Cards. I've downloaded the trial Version to test it.
In my Aja Controllroom i see the input (I used the 2x SDI Inputs on Card/Breakoutbox one). In the Aja Machina I can see the realtime Preview. But in the Resolume Software i cant use the Aja Inputs as a Source.
Did I neeed to install special drivers? I installed the drivers from the Aja Page for Windows.
They are running without mistakes.
System:
- Windows 7 Professional 64Bit
- i7 Prozessor, 12Gb RAM, 512Gb SSD, 750W Power
- 2x Aja Kona 3 (not Kona 3G ore 4) via PCIe
- 1x Nvidia Geforce GTX 940 PCIe
Somebody had any idea?
Sorry for my bad english ;D - im from germany
Re: AJA Kona 3 no Capture Device in source list
Please contact us via the feedback tab in preferences with your log file.
schneidi
Post by schneidi »
In my opinion there should be no mistake in the log because the card is not known as a capture device for all the programs i tried. But i would like to buy the resolume software if the aja cards work fine. I saw that resolume matches with Aja Cards.
Could this be any driver issue ore is the 64Bit system the problem?
I don't know.
Thanks for your answer.
As a reminder, you need to close the AJA software for the source to be available in Arena. So, if you can see the content in a previewing interface on the same computer, that feed won’t be available in Arena.
schneidi
Post by schneidi »
Thanks for your replay.
Yes i know that I have to close the machin software but the software doesnt see any device which can use as capture source.
So if I restart the machine there is the same mistake every time that the source list is empty.
Harmzk
Post by Harmzk »
I am having the same issue? anyway to resolve this?
I have tried all of the above!
Harmzk wrote:I am having the same issue? anyway to resolve this?
drazkers
Post by drazkers »
I kinda thought the Kona 3G had drivers supporting the current API but kona 3 was legacy since it came out before 2010. This correct? The kona 3G and kona 3 are actually pretty different.
satsi
Post by satsi »
Kona 3 is a legacy card not supported in the SDK Team Resolume integrated with 6.x. Kona 3G should work fine.
