Shape + Auto Mask Remnants
A pure white shape with pure white outlines + inverted automask with raised contrast leaves edges.
Re: Shape + Auto Mask Remnants
This is blurring the line between bug report and free form haiku
Do you maybe have a comp file that shows the problem?
It is now attached
The example of a bug
I had then unhatched
The inner color is white, the outer is black, and when it's invert automasked, a rim remains. It remains regardless of the color of the outline, even though it's less noticeable.
A similar bug is when you edge detect a sphere that has its outline and inner color exactly matching, it edge-detects between them
- Attachments
ShaperAutomaskBug.avc
- (60.88 KiB) Downloaded 412 times
Thx for letting us know!
I've created a ticket for this!
