TripleHead2Go Digital SE no Signal
TheBat
Post by TheBat »
Hello,
I have a problem:
I'm using a Windows 10 Asus Laptop. The Asus is connectes with the Triple Head trough a HDMI->DisplayPort caple.
I need to use 3 Beamer, but they only have a VGA Input. Thats wy I brought a DVI 24+5POL to VGA Adapter.
But I just can't find a signal at all.
I got an Runtime Error from Microsoft Visual C++ Runtime Library.
I know my Triple Head is working, cause I used to use it on a PC with DVI cable.
So my Asus is new, my HDMI-Display Port cable and the DVI-VGA Adapter.
I also downloaded the newest Matrox Power Desk.
These are all the information I can give. I don't know where the problem might be and the Matrox Support didn't answer me...
Thank you!
Re: TripleHead2Go Digital SE no Signal
That has displayport input and DVI -D output.
You'll need an active DVI to VGA converter for that.
Running which program?
