sat down to my servers, 2 of them are the same
Mac Pro 6.1 (2013)
2,7 GHz 12-Core Intel Xeon E5
64 ГБ 1866 МГц DDR3 ECC
AMD FirePro D700 6144 МБ
the operating output is set to 3840x2160 resolution, Resolume 6.0.5 and 6.0.7 define it as 7680x4320, while the output is given as 3840x2160.
rebooting and changing versions doesn't help, in version 5 everything is working properly
Bugs, output resolution
Re: Bugs, output resolution
Which OSX version do you have?
OS X Yosemite 10.10Zoltán wrote:Which OSX version do you have?
This issue looks like one we're working on where the Display resolutions is not correctly reported by Resolume with HiDPI resolutions.
(ticket #9653)
(ticket #9653)
I had a similar problem today while setting up a show on several 4k displays (MacOS 10.10):
I've changed their resolutions to 1920x1080 but one of them still appeared as 4k in Arena 6.0.7
In Avenue 4 everything was correct.
