Can you map a key to move up a layer?
brodie
Post by brodie »
Rather than mapping a midi key to a specific layer, is it possible to just be able to hit an arrow key on my midi controller and have Resolume focus on the layer above/below the currently selected layer?
Online
Re: Can you map a key to move up a layer?
This is currently not possible.
brodie
Post by brodie »
Oh, interesting. Is there currently any way at all for me to select a layer that I don't have specifically mapped without touching the laptop?
I'm having a difficult time figuring out how Resolume wants me to work. For example, I've got a mix of video clips that I'd want to play by themselves with the visibility and audio all the way up, I've got some clips with alphas that need a particular blending mode, and I've got clips that should be blended on various other modes. Since the layer properties are persistent from tab to tab, I'd need all of those things on different layers even if they aren't in the same tab. So Resolume seems to "want" me to use quite a few layers, but moving up and down between layers isn't made very easy. Am I missing something? I've been trying to figure out some best practices without much luck so far.
Online
brodie wrote:Oh, interesting. Is there currently any way at all for me to select a layer that I don't have specifically mapped without touching the laptop?
how many layers do you use?
,I've got some clips with alphas that need a particular blending mode, and I've got clips that should be blended on various other modes.
You can set clips individually to be played with a specific layer blending mode in the clip's Video track properties:
https://resolume.com/support/en/clips#video-properties
