Video skipping frames \ shuddering when wav audio added
l0de
Post by l0de »
Maybe a simple issue, have a bunch of mp4 clips, a bunch of wav audio (pcm, uncompressed).
Videos play fine, wavs play fine, but if I load both, the video will stutter on the first few frames and not progress normally. The audio plays without issue. It will continue stuttering on the playback for as long ast the clip plays.
If I encode the audio and video into one track, it plays ok.
What's the deal? Can resolume just not handle what I'm trying to do? These are relatively small files, shouldn't be too taxing. Win 10, latest resolume.
Apologies if this is a common issue, searched a bit and did not turn up an answer.
Re: Video skipping frames \ shuddering when wav audio added
Is this using the embedded audio of the mp4 itself, or after merging them together in Resolume?
Shamai
Post by Shamai »
i had this issue when using a regular h.264 encoded file with audio and just dragging it into resolume
Please send us these files you have issues with playing so we can take a look.
