font solution!
explorer
font solution!
Post by explorer »
hey all ya hi-res users, who dont like the
default resolume font.
here's how to fix your problem:
1.
just uninstall both resolume fonts from your system (Feisar and Feisat-Bold)
after this resolume will use arial (size 12 - a little to big)
2.
use my own fonts tailored specially for resolume. i've tested them with resolume 2.2,
but i guess it will work with older versions as well
if you choose to use my fonts, here's how to instal them:
1.
in the attached files there are 2 zip files. each internal zip contains one version of Feisar.ttf. so you get two versions of the same font.
Feisar-Bold.ttf is not included, and i guess it won't be :)
2.
so unpack one of the files to the local directory (not into the windowsfonts directory)
3.
4.
from the file menu in your windowsfonts folder choose "install new font" option, and choose the file, you've just extracted to your local directory
basicly, its just a procedure of uninstalling one font, and instaling another
the fonts are veeeery similar. some of you won't see the difference probobly. they are a bit missplaced, but i'm still working on it.
feel free to post any coments.
btw... Resolume Developers - GREAT WORK! KEEP IT UP!
Feisar.zip
(22.22 KiB) Downloaded 903 times
sblurg
Post by sblurg »
Much simpler is to erase the Feisar and Feisat-Bold fonts from resolume/fonts and windows/fonts which is all that's needed.
http://www.resolume.com/forum/viewthread.php?tid=1543
[Edited on 13-5-2005 by sblurg]
sblurg
Post by sblurg »
apologies Explorer, I hadn't read the first paragraph. I feel stupid, rightly so
