About 2 computer osc synth problem!
LUZH
Post by LUZH »
I connect 2 Mackbook pro with OSC synth and works fine!
And now I’ve got two different timeline source.
Ex. Master its 20sec loop / Slave its 4:00 full song.
But they play with the same speed!
The 4:00 source goes super high speed
Im wondering its any way to cancel the speed synth
I just wnat to trigger at same time
Sorry for my weak english.
Re: About 2 computer osc synth problem!
Yes, this happens because the "master" sends the playhead's position to the "slave" if you have the OSC output all preset.
You can create your own OSC shortcut preset where you enable only the clip trigger as output.
Have a look at https://resolume.com/support/en/osc#wildcards on how to create these shortcuts.
