NDI VLC Plugin not working in 6.0.7
satsi
Post by satsi »
Hey folks,
It appears that the NDI VLC plugin no longer works in 6.0.7. I rolled back to 6.0.6 and all is working as expected.
In 6.0.7, it doesn't see the NDI source. This is on Windows 10.
Also, as a side note, Newtek is rolling out the 3.5 update soon for NDI Tools. It will now support VLC 3.0.
Re: NDI VLC Plugin not working in 6.0.7
I'm on PC running VLC 3.0.1 and can not even get NDI to show up as an output option for VLC. Sounds like it's aNDI VLC plugin issue.
What version of VLC are you able to the get NDI Plugin to output? And can you see that output via the NDI Monitor app?
If you can see it on your NDI monitor app, but Resolume doesn't see the NDI source, then it might be a Resolume issue at that point.
pfelberg
Post by pfelberg »
I own NewTek products for decades.
I got an email last week with info that NDI tools are improved and updated.
Perhaps you should try downloading the newer versions.
pfelberg wrote:I own NewTek products for decades.
I'm up-to-date ;) :)
satsi
Post by satsi »
Hey Arvol,
I got nailed on this, too...the current NDI VLC plugin only supports VLC 2.x. The upcoming 3.5 NDI Tools release will have VLC 3 support.
satsi wrote:Hey Arvol,
Nice! I was wondering where it went, and then realized I moved to VLC 3.
Thanks for the info :)
