DMX (automap) preset for Arena 6
Due to many requests about this, I have created a shortcut preset that should do the same as the DMX auto map did in Resolume 5.
Please give it a try with a lighting console that has a Resolume 5 Fixture profile, to check if everything works as expected.
Resolume 5 DMX Auto Map.xml.zip
(6.16 KiB) Downloaded 3911 times
Re: DMX automap preset for Arena 6
Zoltán wrote:Due to many requests about this, I have created a shortcut preset that should do the same as the DMX auto map did in Resolume 5.
Awesome! Thanks Zoltan.
I'll try it out later next week. The one I created didn't have these features available:
Composition Playhead Direction
Layer Crossfade Select (A/B)
Layer Move Up/Down
Layer Playhead
Layer Playmode
Layer Direction
Layer Speed
Layer Autopilot
Did you fins a way around that in yours?
https://www.dropbox.com/sh/zig7hzxlfw9f ... YZSZa?dl=0
It absolutely baffles me that people can get super seep into MIDI programming but cry like children because they can't get an automap for DMX :lol:
Do we need a MIDI automap next? haha!
Layer Move Up/Down won't be happening,
Layer Crossfade Select (A/B) seems to be working good in my preset with a single dmx channel.
Layer speed should not have any issues either.
I haven't checked the others you mention tbh, and I don't have a DMX source with me this weekend to check.
drazkers
Post by drazkers »
It really annoys me too. I’ll test on a ma full-size next week.
Joshua Keel
Re: DMX (automap) preset for Arena 6
Post by Joshua Keel »
Any luck on this front with GMA? Trying it with the Avolites program either tonight or tomorrow.
robthirlby
Post by robthirlby »
It works for many parameters but not for some groups without modification of the Lighting board fixture. This is because resolume 6 encodes things differently to res5. e.g. the crossfader bus function used to operate with the values 0,1,2 for off,A,B. Now you must use range values such as 0-85, 100-150, 180-254 for off, A, B. Similarly but with different ranges for the autopilot and such like.
By the way i also was able to use the new next/previous clip functions by mapping them to the unused layer channels 6,7 labelled move up and move down. The trick is to set them to value 1 to trigger the action and then always reset to zero with a follow up cue.
robthirlby
Help ive reinstallled arena 6.1.1 and cant remember how to install your automap xml file
You can copy the preset file it to the Documents/Resolume Arena 6/Shortcuts/DMX folder, restart Resolume, an load it in the Shortcuts panel as DMX preset.
DougLD
Post by DougLD »
Thanks for the information !!!! :D :D
elbundlo
Post by elbundlo »
"It absolutely baffles me that people can get super seep into MIDI programming but cry like children because they can't get an automap for DMX :lol:
Do we need a MIDI automap next? haha!"
Not very funny.
Of course we don't need a MIDI auto map. But we do need a DMX one. Now.
