I have a feeling this is going to be waaaay more work than the payoff, but if it's something simple, and you think it would be useful (or a ton of people +1 it?).
When mapping a blend mode, could you add a toggle mode that allows you to press a single button that toggles between 2 different blend modes?
Just a thought. But this sounds like a ton of work, and if that's the case, don't worry about it haha.
Toggle Shortcut
Re: Toggle Shortcut
Handy feature, I use bomes for that. I’m kinda wondering how they’d want to implement that in the GUI. New option from Dropdown?
Re: Toggle Shortcut
Way ahead of you: https://resolume.com/support/en/keyboar ... ific-items
Re: Toggle Shortcut
Love it! You're so ahead of the curve. Like I'm still stuck back in 2009Joris wrote:Way ahead of you: https://resolume.com/support/en/keyboar ... ific-items
Thanks Joris
Re: Toggle Shortcut
Oooooo I missed that! Thanks Joris!Arvol wrote:Love it! You're so ahead of the curve. Like I'm still stuck back in 2009Joris wrote:Way ahead of you: https://resolume.com/support/en/keyboar ... ific-items![]()
Thanks Joris
Edit. Updating my file and i find i was already using this properly. Jeeeeez Brady get yourself together.
