hi,I have a project with a club,and we bought a new arena 6.0.7,then we have some problums here:
1.we made the advanced output in 5 first,then we moved all settings to 6 folders in my document folder,but all outputs seems not correct(we have 6 outputs total),some displays are In the right order.and i tried to set their display to right output,the last one output seems totally wrong.....
then i tried to reboot the computer,and we replug all mini-dp ,then start arena,we can use it but every time restart computer we need to replug all mini-da again or we can`t find the correct output.............
our videocard is AMD Radeon WX9100 16GB,7800X CPU, INTEL SSD 520 1TB;
and our total resolution is 6607X8849,5 outputs and one laptop screen output,a very huge led surround screens.
and,we also have some crash problums with arena,sometimes computer restart automatic,and sometimes arena crush.but our fps seems stabe at 25-30,but i never meet so huge reoslution,so i am not sure if our resolution is too big to crash arena or overload gpu.
the last one question is about dxv,i can`t export my 6607X8849 resolutions by DXV3 in AME..the maxium size is 8192 i can export,does QUICKTIME maxium export size 8192?.......
these Situations drives me crazy....so i really need suggetions for this...thanks...
Arena 6.0.7 some problums with output and DXV problum,Help!
Online
- Team Resolume
Re: Arena 6.0.7 some problums with output and DXV problum,Help!
This sounds like windows messing with you re-ordering the displays.munk0915 wrote:1.we made the advanced output in 5 first,then we moved all settings to 6 folders in my document folder,but all outputs seems not correct(we have 6 outputs total),some displays are In the right order.and i tried to set their display to right output,the last one output seems totally wrong.....
Computer restarting we can't do much about, might be a driver issue.and,we also have some crash problums with arena,sometimes computer restart automatic,and sometimes arena crush.but our fps seems stabe at 25-30,but i never meet so huge reoslution,so i am not sure if our resolution is too big to crash arena or overload gpu.
Are you overclocking?
If Arena crashes please send the crash report using the reporter that pops up after the crash, so we might be able to find out hat's going on.
Looks like this is a limitation in quicktime, I couldn't find any other quicktime coded where a resolution higher than 8192 was possible.the last one question is about dxv,i can`t export my 6607X8849 resolutions by DXV3 in AME..the maxium size is 8192 i can export,does QUICKTIME maxium export size 8192?....
Here is a sample DXV3 file I made a while back which aas encoded with AME at 11500x2800: https://www.dropbox.com/s/6kpq5p0fdgd9c ... 0.mov?dl=0
8192 is the maximum height! On my end I can push the AME resolution settings to 30,000x8192 so it looks like you might need to render your clip at 90˚!
But in resolume 5 is okay,so how can i fix it.This sounds like windows messing with you re-ordering the displays.
Are you overclocking?[/quote]
No,CPU is using default setting.
Where i can find the report?everytime crash i can`t do anything and the resolume just idle and close...If Arena crashes please send the crash report using the reporter that pops up after the crash, so we might be able to find out hat's going on.
We tried on AME mac is fine,but we tried it on 5 pc AME and no one can render itThis sounds like windows messing with you re-ordering the displays.
MAC is fine to render it ,but on PC even i render it at 90,same errorOaktown wrote:Here is a sample DXV3 file I made a while back which aas encoded with AME at 11500x2800: https://www.dropbox.com/s/6kpq5p0fdgd9c ... 0.mov?dl=0
