Lemur OSC Arena6 Template
He2neg
Post by He2neg »
Hey,
I started to build a Lemur Template for Arena6. When its finished or at a point to share i will do this here.
So far i had a good start (from knowing nothing) and i allready got a few things i want to have on my iPad when walking around.
Master opasity
Strobe button
Bpm Tab
First i want to have some Input what you think is smart to have as well.
And i came to a first Problem i cant solve and also dont find anything in the web.
I want to display the BPM under my bpm tab button. I made a "monitor" inside Lemur, got the right adress (=composition/tempocontroller/tempo/value) and it also display something. But it displays the Float Value between 0 and 1. It should display the bpm 200- 500.
Any hints what to do, change, etc...
Thanks.
~Berlin~
Re: Lemur OSC Arena6 Template
He2neg wrote:I want to display the BPM under my bpm tab button. I made a "monitor" inside Lemur, got the right adress (=composition/tempocontroller/tempo/value) and it also display something. But it displays the Float Value between 0 and 1. It should display the bpm 200- 500.
Can Lemur do math for a display like this?
He2neg
Post by He2neg »
i guess it can do math... but my head has stopped working after i saw the bpm dont start at 0 ;)
x(0-1)=
x*500 -> 0 - 500 BPM
~Berlin~
elgarf
Post by elgarf »
BPM = 200 + X*300? )
BPM (decimal) = x(float) * 480 + 20
He2neg
Post by He2neg »
Okay sure... it is that easy... And now i need some Lemur Pro to tell me how and were to put this^^
Cosmowe!!!!
~Berlin~
He2neg
Post by He2neg »
Ok, maybe the BPM Display Problem will solve, but this isnt a importend feature.
I got another thing i came alonge:
I wanted to map the Slicetransform Effects "Mask" & "Fill" as well
When i see this osc Input for both buttons:
/composition/video/effects/screenlayertransform/effect/scaling
OSCType Tag:
Int 0 through 3
I´m a bit confused now. does this mean i can use a fader and it will jump to the mode 0-25 / 25-50 / 50-75 / 75-100 ?
or do i need to specify a button/pad to send some more information then just the target?
Thanks for everyone helping me with this template.
Here it is so far:
Comp Effects you ll need : Strobe & Add / Substract
Arena6_v1.rar
(2.26 KiB) Downloaded 1736 times
~Berlin~
sleepytom
Post by sleepytom »
OSCType Tag:
Int 0 through 3
these kind of int addresses are an index to each setting.
Fill =0
Fit =1
Stretch =2
Mask =3
So to select the mask mode you send a 3 to /composition/video/effects/screenlayertransform/effect/scaling
He2neg.....I read....and read... this thread every day between work :) ....I would like to give you a correct answer....and for that reason... I first have to test it by my self.... :D I remember that I ran into a similar problem when I was building the Lemur interface....
I would recommend... If you need fast feedback.. download my template... and take a look at the BPM light at the bottom right...I am pretty sure...I did some math there..... :P keep in mind that it was build for R5...and the OSC addresses have changed....
Lemur Sequencer Thread
Hope that helps you for now..... If not... I will take a look at this as soon as I have some more time than I have now.
Best wishes
He2neg
Post by He2neg »
Ahha there he is ;)
I allready did download your step sequenzer and try to "steal" copy past and learn osc that way.
But i didnt knew that you had a bpm indicator so i didnt search for that...
It seams you have a
BPM Monitor invisible :
value : 2+BPM0.x*249
Script : setbpm(): clock_setbpm(0, value);
And BPM0 is a Mulislider.. :?: :roll: :?
But your BPM Light in the bottom Corner just use your stepper as rev:
Script : Tick(): if(stepper.out==1) {x=1;}else{x=0;}
I keep on trying, maybe i get some further with this...
Incoming BPM [0-1] -> Multi Slider -> Set Lemur Clock
~Berlin~
