Mapping on LED
msarathf
Mapping on LED
Post by msarathf »
Any advice about how to decide how many computers need to map on large LED walls
(ex; 32 x 9 )
Empyfree
Re: Mapping on LED
Post by Empyfree »
Give us a clue?
32 x 9 what?
Pixels? Panels? Metres???
The answers probably the same anyway, one really good computer is usually the best way forward , with switching and a backup computer if you can afford it!
Your biggest question is going to revolve around signal distribution from computer to LeD wall processors. And make/model of those will have an impact on your setup.
With more detail we’ll be happy to help!
msarathf
Re: Mapping on LED
Post by msarathf »
Thank for reply, and sorry for lack of information for you to answer well.
size may be 32 ft x 9 ft, or 27 x 9 ft. my video and computer resolution of 1920 x 1080.
In addition, any advice with Graphics card for a new computer for this purpose either Intel® UHD Graphics 620 or
Nvidia GTX1050 Graphics, thank in advance
Re: Mapping on LED
Intel® UHD Graphics 620 or Nvidia GTX1050 Graphics
Intel 620 is an integrated GPU whereas Nvidia GTX1050 is a dedicated one so for sure you should get the Nvidia.
But keep in mind the GTX1050 is going to be fairly limited, so I would recommend getting at least GTX1060/6GB or GTX1070/8G if you can swing it financially. You won't regret it!
Re: Mapping on LED
msarathf wrote:Thank for reply, and sorry for lack of information for you to answer well.
As Oaktown said, Do not use an integrated (Intel) GPU when your other options are much better. I personally would start my recommendations on a 6GB GTX1060 and above. It's worth the extra $200-300!!
What pixel pitch is this wall? 3mm,6mm,10mm?
6mm and above should be under 1080p, but when you start playing with 3mm and the like, you might be entering the 4k territory.
Any modern computer should be able to handle 4k without a problem, the only questions at that point is:
how hard are you going to push it?
20 layers of 4k? that might not work haha, but if you're doing 10 or fewer layers of 4k, a GTX1060 should handle that just fine. a GTX1050 might only get you 2-4 layers? IDK, there might be a GTX1050 benchmark posted on here that could give you an exact idea of what you can do.
But if it's 1080p, you're set for days :)
msarathf
Re: Mapping on LED
Post by msarathf »
A lot of helpful information: Thank you so much Oaktown , Arvol ,Empyfree
