NDI Audio
vmhstech
NDI Audio
Post by vmhstech »
Is there an internal solution for getting audio from an NDI signal so it can be mixed in R6? It is not real NDI if it can not transfer audio. If there is no current solution, when will the NDI functions be corrected?
Additionally, NDI should also carry audio in the output as well.
Michael Ruiz :D
Re: NDI Audio
We have a ticket for NDI Audio support in the features bucket.
We don't have an estimate on when and if this will be implemented.
residenthamster
Re: NDI Audio
Post by residenthamster »
Hope it can be implemented soon, since it can potentially save a lot of cabling in an events production.
RossMcIntosh
Re: NDI Audio
Post by RossMcIntosh »
Would also really like to see NDI Audio implemented if possible.
Input and Output please. Possibly with an option to toggle output audio...?
Thank you for your consideration.
deflost
Re: NDI Audio
Post by deflost »
+1
thx.
r.h.
westfernsehen, leipzig
5AMvisual
Re: NDI Audio
Post by 5AMvisual »
+1 please
Does anybody know of any workarounds over network instead of audio capture cards ?
Edit:
I've found a solution for Mac on: http://www.sienna-tv.com/ndi/audioout.html
Sam
  • HacPRO (Win10/OSX10.13 Render+Mediaserver)
  • i9 9900K OC - 64Gb RAM - NVIDIA Titan Xp 12 GB VRAM
  • MBP 2018 15" - Livid Ohm RGB - Arturia BeatstepPro - DJTT Midifighter Twister
  • Bome MTP - Vezér
Re: NDI Audio
Dante is also a great network audio system for other uses too. https://www.audinate.com/products
5AMvisual
Re: NDI Audio
Post by 5AMvisual »
Zoltán wrote: Tue Apr 07, 2020 17:22 Dante is also a great network audio system for other uses too. https://www.audinate.com/products
Indeed it is !
I can try pushing audio via Dante and video via NDI.
My only concern is sync'ing the two and keep them from drifting..
I'll give it a go using Dante Virtual Soundcard
https://www.audinate.com/products/softw ... -soundcard
Sam
  • Bome MTP - Vezér
Pechorin
Re: NDI Audio
Post by Pechorin »
+1
At least NDI Video+Audio would be great
projectneptune
Re: NDI Audio
Post by projectneptune »
DANTE AUDIO INPUT/OUTPUT WOULD BE SUPER HELPFUL!!!
