Hi:
I am using Resolume Arena 6 Advanced Output to run some video clips, I noticed video clips are significant lagging and unsmooth. In the normal mode, everything is running nicely and smoothly.
My Mac specification is below:
MacBook Pro(Retina, 15-inch, Mid 2015)
Processor: 2.5Ghz Intel Core i7
Memory: 16GB 1600MHz DDR3
Graphics: AMD Radeon R9 M370X 2048 MB Intel Iris Pro 1536 MB
Can someone help me with the Issue please?
Lagging in Advanced Output
Re: Lagging in Advanced Output
Having the same issue with my macbook pro too.
Online
- Team Resolume
Could you send us your composition, and advanced output preset?
I am sending the files, composition and preset output xml. please check and advice where i have gone wrong. the files were so jerky.
- Attachments
- AFA PANELS A.xml.zip
- (10.03 KiB) Downloaded 424 times
AFA PANELS FINAL 11.avc
- (1.91 MiB) Downloaded 497 times
Online
- Team Resolume
Looks like you are trying to drive 5 outputs, with many layer routed slices.PERCYJOSEPH wrote:I am sending the files, composition and preset output xml. please check and advice where i have gone wrong. the files were so jerky.
I think you need a more powerful machine than a macbook pro for this.
