OSC clip playback
theoriz
OSC clip playback
Post by theoriz »
I encountered two problems during a show I made using Resolume 6.0.7 and OSC.
First problem : let's say I want to control clip 1 on layer 3 : if I send "/composition/layers/3/clips/1/transport/position/behaviour/playdirection" and add an int argument between 0 and 3 (as written in documentation) I will only be able to play backward or forward with "0"and "1" values, "2" and "3" values won't have any effect (no pause or random playback).
The second one appeared when I tried to control the same clip timeline position through OSC. Wherever I move the position, the media restarts and then go to the asked position. This doesn't appear when the position is moved with a mouse. A trick I found is to set the media on pause manually (because it doesn't work with OSC as said above) and then move.
Are those bugs known ?
Thank you,
Alex
Re: OSC clip playback
Yes, we're working on it.
Theatre sound engineer, photographer, programmer, aka ravensc.
VJ footage: https://goo.gl/58oHy7
nuvedai
Post by nuvedai »
I still have the same problem.
OSC play and pause (.../direction/2, .../direction/3) don't work, on global, layer and clip levels,
This problem exists both when trying to send OSC messages manually, but also when syncing two Resolume Arenas on two computers through OSC.
nuvedai wrote: Thu Mar 14, 2019 16:55 OSC play and pause (.../direction/2, .../direction/3) don't work, on global, layer and clip levels,
These should be messages to the address:
/composition/layers/2/direction
with an integer argument: 0 to 3
/composition/layers/2/direction/2 address alone won't work.
nuvedai
Post by nuvedai »
Zoltán wrote: Thu Mar 14, 2019 17:06 These should be messages to the address:
I apologize, that's what I meant.
Sending integer / float 0, to an address like /composition/direction or /composition/layers/1/direction, works.
Sending any other number, int or float, always triggers the "play forward" button.
As if inside Resolume Arena the type is actually coded as a boolean (where anything other than 0 is interpreted as 1).
Like I said, this also causes a problem with Resolume's own OSC syncing feature, so it is definitely a bug on Resolume's side.
Which 6.x.x Resolume version are your using exactly?
nuvedai
Post by nuvedai »
6.0.7
Okay, I see something similar was addressed at 6.0.11
I'll update and see.
Thanks.
nuvedai
Post by nuvedai »
Works! Sorry for unnecessary trouble / Thanks for showing the way
AndrewIAm
Post by AndrewIAm »
I am use 0 for Back, 0,33 for Fwd, 0,6 for Pause, 0,9 for Random. And its work
HarryLoop
Post by HarryLoop »
AndrewIAm wrote: Mon Apr 08, 2019 16:53
do you use 6.0.11 too? because after reinstalling does not work for me :?
