I have a show with SMPTE Timecode, and I want play clip without selected it. For exemple I have 4 clips, it started at 01:00:00:00, 02:00:00:00, 03:00:00:00 and 04:00:00:00. It's possible to autoplayed clip, without selected each clips ?
	    	Setting the offset won't launch the clips.He2neg wrote: Fri Jun 08, 2018 10:19 I read the manuall so that it is possible with the "offset".
https://resolume.com/support/en/smpte
A timecode cant start a clip by its own... thats different to what i did with timecode on other media servers..Zoltán wrote: Fri Jun 08, 2018 10:45Setting the offset won't launch the clips.He2neg wrote: Fri Jun 08, 2018 10:19 I read the manuall so that it is possible with the "offset".
It allows you to have a launched clip playing at a different TC position than the incoming TC.
Transparent actually, until the incoming TC is not in the range of the clip's position+offset.He2neg wrote: Fri Jun 08, 2018 16:39 A timecode cant start a clip by its own... thats different to what i did with timecode on other media servers..
But the Output will be black till the clip starts?
Having a pre-roll is a good idea in either case.Oaktown wrote: Fri Jun 08, 2018 15:39 As a note, if you want to first clip to start at 00:00:00.00, you might want to have 1 second of preroll in your timecode
...or you could simplify the process and use Zoltan's OSC controller and set the time code for each cue.
