arena 6.0.8 Bugs
Bassindaniel
arena 6.0.8 Bugs
Post by Bassindaniel »
Hello all.
Here is 2 bugs i found.
- When adding delay on a screen in advanced menu screen changes output scale on screen.
- When adding chroma key to clip and changing clip position and clip on the layer below is cropped.
mmmm... and still sometimes cant quit and reopen arena....
xps 9550
windows 10
:ugeek:
Re: arena 6.0.8 Bugs
Bassindaniel wrote: Thu Jun 07, 2018 14:04 - When adding delay on a screen in advanced menu screen changes output scale on screen.
We'll look into this,
Meanwhile set the display scaling in windows for these displays to 100%.
Bassindaniel wrote: Thu Jun 07, 2018 14:04 - When adding chroma key to clip and changing clip position and clip on the layer below is cropped.
Try moving the chroma key Before clip Transform.
Bassindaniel wrote: Thu Jun 07, 2018 14:04 mmmm... and still sometimes cant quit and reopen arena....
Resolume needs some time to clean up on close, that can take up to 10 seconds. This process goes on when windows doesn't show the Resolume icon active any more.
However if you can't reopen Resolume after 30 seconds, Resolume is probably stuck. In this case you can force quit the application in the task manager.
Bassindaniel
Zoltán wrote: Thu Jun 07, 2018 23:07
30 sec in live show world is death. also 10 sec... :mrgreen:
Bassindaniel wrote: Fri Jun 08, 2018 11:15 30 sec in live show world is death. also 10 sec...
Do you see the issue described in viewtopic.php?f=12&t=15939 and then try to quit?
Bassindaniel
Sometimes. But also when loading as usual...
Bassindaniel wrote: Fri Jun 08, 2018 23:29 Sometimes. But also when loading as usual...
Please send us a screenshot of the clip's stuck loading when the hang happens for you next time.
