Hello everyone,
iam playing around with some effects and would like seperate a specific color and leave everything else transperant. Iam used to have an invert option on Chroma key, which is not the case in Resolume 6. I tried some workarounds but dont get the desired effect despite keying every single unwanted color for each clip. Any ideas ?
Sincerely
Sportinger
						Invert Chroma Key
Re: Invert Chroma Key
Here is a workaround:
						- Use 2 layers, one for the keyed clip (layer 1) and one for a router (layer 2)
 - Turn the opacity of layer 1 to 0
 - Select layer 1 as source for the router and uncheck input opacity
 - ChromaKey the color you want to keep.
 - Select Show Mask
 - In the router, add an Invert RGB effect
 - In the router, add a Colorize effect and select the same color you just keyed out
				Sportinger
this is it. Overlooked the Show mask button.
Thank you very much for that quick response
