Arena 6 With Grand Master 2 on PC
Abhi3626
Post by Abhi3626 »
Hi
I have MA on PC connect with Arena 6 through artnet,
On DMX preference I can see receiving signal from ma but nothing is happening on resolume , on MA2 resolume patch with V4 master auto profile
Please let me know what I can do to to have control of resolume on ma
Thanks , much appreciated
Abhi
Empyfree
Re: Arena 6 With Grand Master 2 on PC
Post by Empyfree »
You won’t get far using V4 profile on Arena V6!
Try some simple mapping to start with. Patch a couple of dimmer channels (in the correct art net universe) then try assigning those to functions you wish to control. If you can get that working you can build from there.
If you map the channels from the R4 profile in Resolume 6, you can use the profile just fine.
Have a look here how to map DMX shortcuts: https://resolume.com/support/en/dmx-shortcuts
