Fixture names not saving
elecdashtron
Post by elecdashtron »
Im on Resolume Arena 6.0.9 but ive had this issue for a while
In fixture editor, when renaming a fixture it often goes back to its original name and doesn't save. It seems to happen when duplicating fixtures.. ANy idea?
Re: Fixture names not saving
Do you [Save & Close] the Fixture Editor window or just [Close]?
elecdashtron
its hapening before i get a chance to save
eg.
say i create a new fixture then rename it,set ust parameters and scroll up and down the liat of fixtures to edit another one, the fixture i just created is just called New Fixture and my name change doesnt take. the param values are saved however and when i lookinside the fixture directory the name of the fixture IS the name i set
Thanks for letting us know!
I have created a ticket (11456).
The fixture appears in the fixture selector with the correct name, and adding another new fixture makes the name display correctly. So this should not cause too much trouble.
