External audio input not working
Nackgi
Post by Nackgi »
I'm having some problems with external audio input. When I select any input channel from "External Audio FFT Input" -dropdown menu, audio input selection resets to "Select input device" and I cant get any sound in.
(See attached image)
At the moment I am using Virtual Audio Cable to bring the sound in but the same happens with all the recording devices.
Any ideas what could be the problem?
Re: External audio input not working
Looks like using your inputs is a windows privacy setting now since the latest windows update.
Go to windows Settings > Privacy > Microphone and make sure “Allow apps to access your microphone” is active.
https://www.thewindowsclub.com/windows- ... ing-update
Nackgi
Post by Nackgi »
Thank you! That fixed the issue.
7177y
Post by 7177y »
I'm having the same problem with a 2018 macbook pro. And I think it's also bc of privacy settings but I just don't know how to tell resolume AND the macbook that it's totally fine using the built in mic. not even creating an aggregate device brings any help :((
x
7177y wrote: Fri Sep 28, 2018 20:24 I'm having the same problem with a 2018 macbook pro.
Looks like microphone became a privacy thing in OSX Mojave.
Try getting the latest installer from our download page and re-install Resolume.
On the next Resolume start, you should get the notification prompt to allow the use of the microphone by Resolume.
gos-com-fuig
Post by gos-com-fuig »
I'm having same problem,
I have Mac Book Pro, High Sierra 2016 and I'm up to date with new Resolume Arena 6
I'm trying to input audio using Loopback so I'm 100% positive that the audio is registering in the two chanels, however, in Resolume the sound doesn't enter.
Not even Built-in microphone. No in signal whatsoever.
gos-com-fuig wrote: Sun Dec 09, 2018 15:12 I'm having same problem,
Could you send us a screenshot of your audio preferences in Resolume?
gos-com-fuig
Thank's Zoltan!
gos-com-fuig
Sorry, sorry! Got it!
Didn't see the External Audio FFT Input (Is it's placement a bit out of the way?)
Crazy_Lion
Post by Crazy_Lion »
Hi, I have the same issue and I can't even scroll down the SMPTE input... It's all in grey, like unselectable.
Is it restricted by the demo version ? I was hoping to test a few thing before a huge gig in my town..
