MIDI Bank Select (CC0) as clip trigger?
bigjoescientist
Post by bigjoescientist »
Has anyone figured out how to use MIDI Bank Select (CC0) & Program Change to trigger clips? I'd like a different specific clip to trigger each time I switch to a new patch on my master MIDI controller. Fwiw, I am able to get MIDI Note and other CCs to trigger clips.
kkinerk
Re: MIDI Bank Select (CC0) as clip trigger?
Post by kkinerk »
I am interested in this as well. I have no issues using Midi Notes to trigger Resolume, but I have MIDI foot pedals and they all support Program change messaging.
Can we get support for Midi Program Changes Messages?
CC0 works for me already to launch clips, simply select the clip you want to trigger in Midi shortcut mapping then send the CC0 to map it.
You can map it to the layer Connect Next Clip button, then when sent the message, it will launch the next clip in the layer.
Program change messages are indeed not supported currently.
Do these pedals you use support CC-s or notes?
