Resolume Crashes on Selecting Output
newvisions
Post by newvisions »
When selecting an output in Arena 6, Resolume crashes. It doesn't matter if it is Full Screen, Windowed, or selecting the screen in Advanced. I just had to run a whole stage at Electric Forest by mapping in 6, and then sending Spout to Madmapper, which works fine but it's not preferred.
I'm using a brand new Alienware with a i9-8950HK, 32 GB of RAM, and a Nvidia 1080. The log files are somewhat cryptic, and I can't find the culprit. It's filled with lines such as:
  • ERROR: Escaped from error in rj::OutputDevicesRenderer::renderFrame(287): Failed to activate primary context.
  • WARNING: ra::getDeviceCategory: Cannot get category, 'HIDClass' class name is not recognised.
I've tried several fresh versions of 6, and several Display driver versions as well. I've also tried disabling all non essential processes on startup.
Any help would be appreciated.
Re: Resolume Crashes on Selecting Output
Thanks for the log file.
Sounds like you might experience the same issue as in this thread: http://resolume.com/forum/viewtopic.php ... it=optimus
Is that correct?
newvisions
Sure seems like it.
I went into device manager and disabled the integrated graphics (Intel UHD 630). Now everything works perfectly!
Thanks for the quick response. Who needs integrated graphics anyways?
