A Few remarks regarding the pan tilt zoom for NDI HX camera's
mkusmic
Post by mkusmic »
A few remarks regarding the pan tilt zoom for NDI HX camera's:
A. Brilliant to have the option!
B. If you're using a seperate camera operator doing alle the shots from a controller you would not want the selection of the NDI source leading to the pan tilt zoom focus values of resolume being transmitted to the camera, you should be able to turn this part off per clip.
C. If you turn on autofocus it does not clearly indicate that it is turned on. Maybe the button should highlite.
D. Using a Panasonic HE40 pan, tilt, zoom and focus seem to have quite a large step size. Probably difficult to match to the value system in Resloume.
E. In the future it would be nice to have the possibility to recall a preset number in the camera.
Best Regards,
Milo Kusmic
Re: A Few remarks regarding the pan tilt zoom for NDI HX camera's
Thanks for the excellent suggestions, Milo. We've noted them down and hopefully we can use them to improve the NDI PTZ support.
Great that you're digging this feature btw!
GruffaloBill
Post by GruffaloBill »
We also use Panasonic PTZ cameras (AW-HN130), and would like to echo all of the above points! Especially the ability to disable the PTZ recall when the source is selected - the integrated controls are nice, but we will always be using a dedicated controller instead.
djad1200
Post by djad1200 »
Just wondering if the ability tor turn off PTZ recall, mentioned above, was ever addressed. Just got a PTZ NDI camera and its quite annoying!
A.D
PTZ controls can't be disabled currently in NDI clips.
We see how it could be very useful, we have a ticket for this.
