Cue point set bug
Moreno oro
Cue point set bug
Post by Moreno oro »
https://youtu.be/YDamLjuNvOM
Been having this bug since R6 released,
while setting CuePoint1 the other cues getting a set/data as well
this bug set happening in a random way sometimes its all the other cues sometimes its a few cues
anyone has a solution for this?
Re: Cue point set bug
Which Resolume version do you see this with?
Is this a Resolume 5 composition you use originally, and could you send it to us?
Moreno oro
wrote this at R6 6.0.10 now with R6 6.0.11 same bug
Thanks for the composition, I can't find the clip you have in the recording.
And adding the media to existing clips or adding new files to the composition I can't recreate the issue you see.
Does this only happen for you with that specific clip you have in the video?
