BUG FPS 30.25 in the recorded loops
CHOURAQUI
Post by CHOURAQUI »
still have same bug (since R6 0.6) on vids produced via the RESOLUME record, they play badly in QUICKTIME continuous hiccups
reason seems recorded in RESOLUME they have a strange FPS 30.25 !!!
version R6 0.5 and preceding ones works ok and the recorded loops have FPS 30 and plays correctly
Re: BUG FPS 30.25 in the recorded loops
Looks like quicktime has issues playing Resolume recordings.
Does the file play fine in Resolume or other programs?
CHOURAQUI
Post by CHOURAQUI »
resolume recorded file plays without problem in vlc and in RESOLUME
and plays well in QUICKTIME after a simple export with the same PHOTO-JPEG codec and .mov ,
difference between before and after-export is just the FPS value the strange (bugged?) 30.22 FPS for the RESOLUME recorded file before export
CHOURAQUI wrote: Tue Aug 14, 2018 08:05 resolume recorded file plays without problem in vlc and in RESOLUME
Seem to be an issue with quicktime then.
CHOURAQUI
Post by CHOURAQUI »
sorry too easy "it is not me it is the other" answer" , the 30.22 FPS for RESOLUME recorded files is not normal, RESOLUME preceding versions since 6.0.5 works well (RESOLUME recorded files are normal value 30 FPS and not 30.22 !!)
