Onboard output for auxiliar monitor
VinicDiet
Post by VinicDiet »
Hello everybody...
I would like to know if its possible to use the VGA onboard output for the auxiliar monitor.
I have already tried this already but it turns fps really slow?
Am I doing something wrong or it's not possible to keep fps normal?
Best Regards,
Vinicius
He2neg
Re: Onboard output for auxiliar monitor
Post by He2neg »
Resolume will chose the card for rendering depends on were your control Monitor is plugged in.... maybe this can solve your problem ;)
~Berlin~
VinicDiet
Post by VinicDiet »
So you believe I should put the main monitor in the graphic card and a projector in the motherboard output?
drazkers
Post by drazkers »
VinicDiet wrote: Thu Aug 16, 2018 19:54 So you believe I should put the main monitor in the graphic card and a projector in the motherboard output?
Everything in the graphics card.
VinicDiet
Post by VinicDiet »
Ok... I use to do that. But I need one more monitor. That's why I would like to use the Motherboard output for the reference monitor.
Have a look at this thread on your options for many outputs: viewtopic.php?f=7&t=15035
VinicDiet
Post by VinicDiet »
He2neg wrote: Thu Aug 16, 2018 19:14 Resolume will chose the card for rendering depends on were your control Monitor is plugged in.... maybe this can solve your problem ;)
It works perfect...
Thank you very much...
Best regards,
Vinicius
