Undocumented OSC commands? Looking for BPM resync.
gpvillamil
Post by gpvillamil »
I am in the process of updating some of my good old Max patches (sequencer, chaos mode) to support Resolume 6. I know AutoPilot now does most of that, but hey, sentimental.
I've been able to easily update clip triggers and BPM setting, but I am missing the Resolume 6 equivalent of
/playbackcontroller/resync/ 1
That would resync the BPM counter to the beginning of a 4 beat bar. Can you tell me what the equivalent is for Resolume 6?
On another note, I love the polling feature. I remember asking for that a long time ago, glad it is there!
gpvillamil
Re: Undocumented OSC commands? Looking for BPM resync.
Also:
I don't know if these are good examples or not. You're supposed to be the creative mind here. I never get to do anything cool with OSC anymore because I'm stuck in an office writing a manual that no-one reads.
I read the manual!
gpvillamil wrote: Thu Aug 30, 2018 21:30 I read the manual!
You sure? ;)
So how do you figure out what the address is for a particular control? Although there is a certain
logic to it, it's easiest to just enter OSC Shortcut mode (Shortcuts > Edit OSC), and click the desired
control.
The Shortcuts panel will show you the correct address. You can click the address itself, ready for
copypasta goodness.
https://resolume.com/support/en/osc#osc-addresses
gpvillamil
I tried that, but... duh, I'm an idiot! There it is, all spelled out in uppercase RESYNC!
Thank you for your help, and your patience!
Zoltán wrote: Thu Aug 30, 2018 21:38
You sure? ;)
control.
copypasta goodness.
