trigger next clip?
soup@liastudios.com
trigger next clip?
Post by soup@liastudios.com »
Sorry looking for the trigger next clip option? I don't have enough midi space to have a button per clip so I'm going to have each layer simply have a trigger next and last clip and then maybe a trigger random clip on layer?
Hopefully this is an option; i'm coming from VDMX where everything was possible.
Empyfree
Re: trigger next clip?
Post by Empyfree »
Start your midi mapping, when you do small buttons appear next to the layer transition control area that you can map to next/last clip.
Not sure about “random” though! You could have a clip which is a transparent “solid colour” and then set its autopilot function to random clip next, you can then piano trigger that clip?
