Datapath ES1 Capture
maspencenk
has anyone ever used datapath ES1 as a DVI / VGA capture? my resolume doesn't recognize the device in the source menu.. but it works on Wachout and vMix.. is there an idea or solution?
Re: Datapath ES1 Capture
Which Resolume version are you using?
maspencenk
I use Resolume 6. I've found the solution. Just reflashing the card with the new firmware.
nearby girls for live chat - https://privateladyescorts.com - real discreet encounters
Yah you need the firmware and the right drivers. I have test ES1 and ES2 from datapath.
