Resolume 6.1.0 Sync to the DJ
The 6.1.0 release is a major point release, which means we added a big feature. As we announced a few weeks ago, we made it a lot easier to sync a prepared video set to the audio coming from the DJ.
If you work with a DJ that mixes on a Denon setup, you can sync every video in Resolume to every track on the players. You can read all about that in the manual. Suffice to say, this will make banging out those DJ intros and special show moments a piece of cake.
We also have a handful of bug fixes. If you're using multiply a lot, make sure you peek the warning below! Otherwise, just hit that download.
Multiply Mixer Warning
We fixed the jump cut when ejecting a clip from a multiply layer using a transition. The multiply blend now works the same as in Photoshop. So far so good! This also means that when using the multiply blend in combination with content that has transparency, the visual result will be slightly different, also in existing compositions. If you prefer the old look, you can disable the alpha channel in the content.
Hotfix! September 20th.
The Opacity fader of a layer was not working correctly when it was playing a SMPTE synced clip. Fixed in Arena 6.1.0 rev61231. Simply download Arena 6.1 again to get this latest revision.
Fixed
#11629 (closed) Make multiply mixer transparency aware
#11598 (closed) DMA Textures crashes with HAP q alpha
#11405 (closed) Crash loading certain TIFF files
#11609 (closed) Hue rotate after Iterate or Fragment not processing pre multiplied colors correctly
#11574 (closed) Fix Rings generator not outputting correctly premultiplied colors
#11573 (closed) Fix LineScape generator not outputting correctly premultiplied colors
#11571 (closed) Fix Lines generator not outputting correctly premultiplied colors
#11569 (closed) Fix checkered generator not outputting correctly premultiplied colors
francoe
Re: Resolume 6.1.0 Sync to the DJ
Post by francoe »
Last time I've saw denon hardware on a stage was almost twenty years ago.
Is that a common thing in europe? Is usual hardware there, or a great reso.bonus?
Love the fixes.
I still recommend a simple multiply filter to get rid off all that situations we know.
francoe wrote:I still recommend a simple multiply filter to get rid off all that situations we know.
What do you mean by that?
drazkers
Post by drazkers »
Oaktown wrote: Thu Sep 06, 2018 15:26
Posting because i wanna hear the answer to this.
A lot of the information regarding the new multiply blend mode is in this thread.
francoe
Post by francoe »
Thanks for the info Oaktown. I know this is about blending. Is just everytime I see that word miss the ability of multiply straight alpha (when you crop, mask,key.. even after transform). You know, the simple thing :D
Mc128k
Post by Mc128k »
Great to see some integration, although 90% of the sets here (italy) are Pioneer CDJ. It would have been nice to have at least the bpm input from them via network, but anyway hopefully we will get there.
He2neg
Post by He2neg »
As i stumbled around here but didnt every read here about this :
https://www.tc-supply.com/
I just drop this here.
Its software to Connect to Pioneer DJ Hardware.
I never tested it but i can imagine that its somehow possible to get the bpm somehow into resolume ;)
~Berlin~
drazkers
Post by drazkers »
He2neg wrote: Tue Oct 02, 2018 21:50 As i stumbled around here but didnt every read here about this :
They recently have added a midi, but also creates Ableton link for resolume.
100 USD a month or 2k outright.
Mac only tho.
Greenfielt
Post by Greenfielt »
I've tried this yesterday in a live setting.
3 CDJ's + 1 DJM (nexus versions).
https://github.com/Deep-Symmetry/beat-link-trigger
On a macbook which was linked in the same network as the CDJ's.
There are some glitches, but the most works without any problem.
It's open source, maybe you guys at resolume can use his knowledge? :)
