Editing Keyboard and Saving Composition
pfelberg
Post by pfelberg »
Hello.
I have some compositions with edited keyboard so that I can apply some effects by simply piano playing those keys. Today I just copied all those compositions to another computer but it seems that mapped keys are saved within the composition file. Am I wrong?
Paulo
Re: Editing Keyboard and Saving Composition
With Resolume 6 the shortcuts are separate files, you also need to copy these to the same location.
They are in Documents/Resolume Arena 6/Shortcuts.
After copying, you need to restart Resolume, and your preset should be loaded when loading the composition.
pfelberg
Post by pfelberg »
Thank you!!!
