Touchdesigner column controller
Grimm90
Post by Grimm90 »
Hi !
As an alternative for having a "play clip X amount of time" before it autopilots to the next one , i made a touchdesigner patch to control the column triggers over time, either for composition and or on group level.
It's an easy OSC control patch which can be customized for other uses too.
There is a play/pauze button and a speed slider for the "next column" button to control composition column trigger , and for group 1 , 2 & 3 .
You can change the speed sliders range in the MTH node .
You can also use this timer to control other things over OSC by changing the OSC adress in the "Rename" nodes (just make sure to leave the first "/" out of the osc adres you copied from resolume)
Touchdesigner Autoplay Resolume.7z
(6.98 KiB) Downloaded 1507 times
Grimm90
Re: Touchdesigner column controller
Post by Grimm90 »
Now with a simple working UI !
If anyone wants to adapt or build on this , feel free to
Touchdesigner Autoplay Resolume 2 UI.7z
(8.49 KiB) Downloaded 1334 times
francoe
Post by francoe »
Too much downloads and no comments. I will try it, thanks Grimm. ;)
