SMPTE Timecode weird behaviour
Aux
Post by Aux »
Not sure if bug or feature ;)
Using V6.1.0 rev 61162 on Win10.
When I link the transport of a clip to an incoming SMPTE signal the opacity of the layer the clip is in jumps to 100%. When I try to bring it back down, the slider automatically jumps back.
Is this expected behaviour?
The workaround/solution is to use the mix slider instead to control opacity, but that means having all of the audio controls visible in the set just for this.
Re: SMPTE Timecode weird behaviour
Looks like a bug to me.
Thanks for letting us know!
Aux wrote: Fri Sep 14, 2018 10:31 Not sure if bug or feature
We have released a hotfix for this, simply get the installer again from the download page.
