How to add Shortcut tab in the GUI?
applehead
Post by applehead »
Hi All,
I am not able to figure it out how to add the shortcut tab to my GUI( by default it shows Files ,composition ,effect and sources)
I know when I click on the shortcuts on the top menu , the EDIT MIDI option will bring up this option BUT I would like to know if there is a way to have access to my presets in the play mode , without going to the edit mode.
Thanks in advance
Re: How to add Shortcut tab in the GUI?
The shortcuts panel only shows in shortcut editing mode indeed.
It's not possible currently to show it if you are not editing shortcuts.
