Visual and Sound, Time lag Problem
mmnn
Post by mmnn »
Hi, I have a Probrem.
I using Resolume Arena 6 , usually I make my Visual On After Effects, and convert to DXV on Media Encoder.
But Visual and Sound it will born Time lag. It often happens.
Media Encorder's version is cc2017 is OK (not born Time lag),but cc2018 it will be.
Is there someone who understands the cause?
Thanks.
Re: Visual and Sound, Time lag Problem
Could be the one were the DXV Adobe plugin doesn't set the FPS correctly: http://resolume.com/forum/viewtopic.php?f=12&t=17445
Does that sound familiar?
Alchimist
Post by Alchimist »
Check sound resolution in AE export, it should be 48Khz. If it is 44.1Khz that is your problem.
