DVX 3 Adobe importer doesn't import some files
elgarf
Post by elgarf »
This file is JPEG2000 with alpha, and AE or AME can't import it with DXV3 importer plugin =(
https://www.dropbox.com/s/6d6sf5zwif86t ... a.mov?dl=0
Re: DVX 3 Adobe importer doesn't import some files
DXV adobe plugin doesn't try to import other than DXV files.
Adobe still shows the DXVplugin as importer for some reason, we're in contact with Adobe about that.
However the File doesn't play right in VLC, doesn't play at all in quickview, and also can't import it to AME without having the DXV plugins installed either.
Imports and plays in Davinci Resolve however.
elgarf
Post by elgarf »
On CC 2017 DXV importer completely replacing QuickTime importer (maybe it's just not actual info from Adobe software).
This file also works ok in MPEGStreamclip.
