Resolume Arena 5 CRASHING - HDD problem?
Walruzz
Post by Walruzz »
i am experiencing lots of crashing in my composition is it because the videos are being pulled from 3 different hard drives at once?
i read this Hard drives usually connect through the SATA ports (Serial ATA) directly to the motherboard and do not directly affect other parts. The only load hard drives bring to the system is power consumption, so the PSU (Power supply) is the only other component that has to work "harder".
Even external hard drives do not slow down a system.
i am willing to spend $$$ to upgrade my system the current specs are
Nvidia GTX 1060 6Gb
CPU AMD Athalon II X2 250 3.00 Ghz
14Gb RAM
Windows 7 64 bit
500Gb SSD SATA
1Tb HDD
2Tb HDD
Any help is really appreciated!
Re: Resolume Arena 5 CRASHING - HDD problem?
What kind of files are you using and how many?
What's the memory usage for Arena 5 right before the crash?
