Advanced Output Slice Reverting size
drazkers
Post by drazkers »
If you create the x/y/w/h of a slice via the quick method(just typing numbers with spaces), physically resize the slice with the mouse and then type the X/Y using the quick method again the W/H of the slice reverts back to its original size.
Re: Advanced Output Slice Reverting size
Which Resolume version are you using?
Mac or Windows?
Is this also happening for you if you create a new Advanced output preset?
drazkers
Post by drazkers »
Zoltán wrote: Thu Oct 04, 2018 08:37 Which Resolume version are you using?
Mac or Windows?
Windows 7 have had it happen on two machines. I had it consistently happening, went back to recreate and take a video, now its not.
I'll keep working on recreating the steps, but its the fourth time i'd had this over the last year, i need to figure the exact sequence. But i do believe it starts with a new advanced output file.
