Text
Lauraiaco
Text
Post by Lauraiaco »
Hi !
I would like to know how can i add a black background (as a little black square ) to my text ?
Please Help me i’ m desesperate
AdevProjects
Re: Text
Post by AdevProjects »
This is one way to do this (see screenshot).
This is probably overkill if all you need is a solid box behind the text.
I used the Shaper source as the base clip then the Text Animator effect, followed by a drop shadow. You can change the roundness of the box corners with shaper.
Empyfree
Re: Text
Post by Empyfree »
That’s a really neat way of doing it! I’d have gone straight for a third layer, your way is much more efficient.
