Multiply 50
Multiply 50
It would be really nice to have an option for a multiply 50 blend mode. The Res 6 feature to have clip re-callable blend modes is awesome, and with envelopes a lot of installations are now possible, but I find myself being unable to use multiply blend mode the way i like to with a recallable mode, because clip opacity isn't the same as layer opacity and i would need to set the layer to 50%. Same goes for difference and Difference I. Also, the ability to toggle Masks per clip would be super handy. Thanks for listening!
Re: Multiply 50
In the meantime, you could add an envelope to the opacity and have it flatline at 50%
Re: Multiply 50
Can you be more specific in your actual need? Are you using setting your layer at 100% for another blend mode?drmbt wrote: Sat Oct 20, 2018 22:12 It would be really nice to have an option for a multiply 50 blend mode. The Res 6 feature to have clip re-callable blend modes is awesome, and with envelopes a lot of installations are now possible, but I find myself being unable to use multiply blend mode the way i like to with a recallable mode, because clip opacity isn't the same as layer opacity and i would need to set the layer to 50%. Same goes for difference and Difference I. Also, the ability to toggle Masks per clip would be super handy. Thanks for listening!
Right now, when a layer is at 50%, Multiply works as if the blend is 100% so if you tested the same combination in Photoshop, to get the same result you'd have the layer opacity at 100%.
So, when a Multiply layer is set to 25%, it's equivalent to 50% in photoshop. In other words 50 Multiply at 100% in Resolume would be equal to 100% Multiply in Photoshop and make the blend mode behave the same way in both programs. Is that what you're after?
Re: Multiply 50
Let's be blunt. Which of the 'non-50' pixel blends is actually useful as a layer blend mode without an envelope transposing the range to 0-50?
