Clip preview/launch midi
4omp
Post by 4omp »
Hi!
Interesting how can i midi map resolume like one button send clip to preview, another button trigger clip to output. Buttons that send clip to preview - different, button that send to output - one for all (like play button). I can't find parameter "active clip" in midi map, but this i think can solve problem.
AND
how can i midi map preview monitor to button, like right mouse button to eject clip from it?
Re: Clip preview/launch midi
You can map the clip's name handle to have it preview.
and similarly the clip's thumbnail handle to the clip launch (output)
https://resolume.com/support/en/midi-shortcuts
4omp
Post by 4omp »
thank u! but this is not what i want )))
How about selecting an empty clip slot to preview?
If you don't mind me asking, why would you like to eject clips from preview via midi?
4omp
Post by 4omp »
1) yeah i can do it, but i have 6 decks with full of clip, and sometimes need to preview new content before push it to the screen and will be more effective to have midi activation button to clip that is in preview now
2) i think that it is very effective and much faster to work with midi controller and control everything with it.
4omp wrote: Sat Nov 03, 2018 22:42 will be more effective to have midi activation button to clip that is in preview now
ok, I understand now ;)
Moved to feature requests.
Stanislav Deryguz
Post by Stanislav Deryguz »
4omp wrote: Sat Nov 03, 2018 22:42 1) yeah i can do it, but i have 6 decks with full of clip, and sometimes need to preview new content before push it to the screen and will be more effective to have midi activation button to clip that is in preview now
Okey! but if you want to preview by 40 buttons, and you trigger it by play, for play button you may use target as Selected Clip !!!which is not available! cause preview going to select that clip. After triggering Resolume stop preview but still keep selected that clip. in this case stop preview is useless. (as for me)
Or not!? :?:
NiceTrip
Post by NiceTrip »
4omp wrote: Thu Nov 01, 2018 17:03 thank u! but this is not what i want )))
How do I map a MIDI button to "play selected (previewed) clip to output"?
